查看: 14|回复: 0
Welder clicking- no wire feed
发表于 2022-9-16 15:52:11 | 显示全部楼层 |阅读模式
When I pull the trigger on my mig  welder, I get a clicking sound and no wire advances. I have a manual advance and that works fine, so the motor is good and wire is not clogged in the line. The clicking sounds like it's coming from the capacitor ( I have 2 capacitors Sprague 45000  45Vdc) If I advance about 2" of wire manually out of the gun, then touch that wire to what I want to weld and pull the gun trigger, the wire gets red hot, but wire will not weld or advance. Wire will only advance when I use the manual advance wire switch.HELP
Reply:The torch trigger switch energizes a relay that energizes the contactor block which is a series of copper  blocks or plates the releases the welding current. I always check the trigger switch, the relay, and the contactor block. My guess it is the very mechanical contactor block.Weld like a "WELDOR", not a wel-"DERR"
MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-18 09:25 , Processed in 0.066952 second(s), 18 queries .
