Lincoln 250 - Gas solenoid does not have 12v - need help
发表于 2022-8-15 15:52:24 | 显示全部楼层 |阅读模式
Hi Everyone,I have a wire matic 250 and gas solenoid valve only has 6 .6 volts not 12, according to the user manual they say to replace the board.  Does anyone know how to trouble shoot the board or possibly check something else.I am checking J8 at pin 3 and 4 and have 1/2 voltage on my digital meter ?Thanks!
Reply:Hi,I figured it out... no need for help on this oneDave
Reply:Good deal.  However, rules are if you post a question on troubleshooting, you have to tell us what was wrong.
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I have the same machine with the same exact issue. Any answers would be very helpful.
GMT+8, 2025-12-18 09:55 , Processed in 0.094897 second(s), 18 queries .
