查看: 14|回复: 0
Widening an Old Alaskan Fishing Boat
发表于 2022-8-14 15:51:41 | 显示全部楼层 |阅读模式
Widening her from 21.5 feet out to 36.5…Doubling fish hold capacity from 150k lbs to 300k lbs.All new refrigeration system.All new hydraulics / deck equipment.New mast / rigging.New aluminum top house. All done in the great state of Oregon.
Do you really know all of the work that goes into getting that fish onto your plate?
Reply:That's quite an endeavor! WowSent from my SM-G973U using Tapatalk
http://www.philswelding.com
Reply:You do know that's not going to fit down the road on a trailer now, right?
Is this a quoted project or by the hour?
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Man..........I dunno........  I know absolutely nothing about boats.It looks unsafe.  I'd wonder how it would react to heavy seas.  I don't see how that can knife through large waves.  I'd also wonder if the powerplant can push it enough to make headway in heavy seas.  Whoever designed it, turned it into what looks like a barge.  Gotta be a huge amount of resistance created by that wide guppy hull.And........I wonder about the leverage on the main hull from those "pontoons" y'all hung on there.I know you didn't design it, you're just gluing it together, so I don't mean to put your work down.I've seen pics of some of the Norwegian fishing boats, and they do have a stubby, stumpy, dumpy,, hull..........so maybe I'm all wrong.I better stick to what I know
Originally Posted by farmersammm
Gotta be a huge amount of resistance created by that wide guppy hull.And........I wonder about the leverage on the main hull from those "pontoons" y'all hung on there.I better stick to what I know
Reply:I've never seen a boat widened like that, but seems simple and a hell of a lot cheaper.Hope everything works out great for you.
Originally Posted by duaneb55
Member beaver posted a similar project back in '18.https://weldingweb.com/vbb/threads/7...fishing+vessel
Reply:Thanks all for the positive words. Yes, it’s a relatively “common” practice, referred to as sponsoning.The boat was laser scanned a few years back, and the design was created thorough my feedback to a naval architect. From there, the design went to a lofter - who created all of the cut files and weld procedure/assembly details. We’ve got a couple more months to go, as a lot of the work will be in setting up all of the vessel’s new systems.Do you really know all of the work that goes into getting that fish onto your plate?
GMT+8, 2025-12-17 11:07 , Processed in 0.060655 second(s), 18 queries .
