Dial Arc 250p is kaput.
发表于 2022-8-7 15:51:47 | 显示全部楼层 |阅读模式
Flipped the switch and the fan comes on but it will not weld. Tried it on low, high and AC and DC. Hit the reset. No luck.It was working fine two days ago. Darkness caught me so I did not have time to switch out the leads which I will do tomorrow.If I have to open it up, what is the main things to look for?
GMT+8, 2025-12-18 17:34 , Processed in 0.117298 second(s), 18 queries .
