Spray Paint-Powdercoat-Black Oxide
发表于 2022-8-7 15:51:46 | 显示全部楼层 |阅读模式
I am new here and had been taught welding basics from a nearby shipyard and furthered some education in an adult afterhours education program and have been away from welding for 20 years. I am just getting back into it since I have purchased a tig welder in the last year which I have longed for.I have been toying with the idea of purchasing a cnc plasma cutting table and I was wondering what people prefer coating there products with.   I understand each has its own purpose but I wanted to hear from others what they think of powder coating vs spray painting vs black oxidation.
Reply:Powder is OK but a lot of cleaning need for powder to stickPaint is simple and will last a long timeBlack oxidation needs to sandblasted before bluing There is also plating simple for copper plating root kill from hardware store and old copper wire.Dave
Reply:root kill, like round up.
Reply:Copper sulfate for tree roots.Found in plumbing section.  It is used for sewer lines.Dave
Reply:A lot depends upon the use of the item. Plus the size of the item. Small items may be put in typical sand blast cabinet, then power coated and baked in an toaster oven, regular sized oven, or you can make your own oven. There is a member here by the name of "acourtjester". Search on his name and powder coating and you can see an oven he made. He has also made and sold several plasma tables. I have a plasma table. I either let my items rust or use spray paint. If required by the customer, I send out for powder coating. I do not have the room for a blasting booth and oven big enough for some items I make. Sent from my SM-G996U using TapatalkMillermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:Thanks.  I have a 18x21 carport I am just starting to convert to a shop, I cant imagine me being able to do everything in that little space.
Reply:After it is copper you can Nickel plate at home witch looks like chrome plate and is safer to do. Dave
Reply:It depends on size of work. For painting I use a bread rakes from bakery.  It can roll out size for painting then roll inside for drying overnight. Dave
Reply:would be a good idea, I have made several crabs and had them zinc plated and I do plan on building more of them.  I had originally made 11 of them and now I have to tell people no because they are also a deco piece for the resturant I run.   Nickle would be a better outcome then the clear zinc.   Thanks man
Reply:Good luck.Dave
GMT+8, 2025-12-17 08:42 , Processed in 0.201057 second(s), 18 queries .
