查看: 14|回复: 0
Bobcat 225 NT wont stop running
发表于 2022-8-7 15:51:45 | 显示全部楼层 |阅读模式
Had an issue with a 2003 Bobcat. Starts & runs fine, but won't die when you turn it off. I figured the fuel solenoid was the issue, tore it down so I could get to it, pulled it out & tested it, seemed to work fine. (Pull 2 screws, take it out & ground it with key on & it should pull back). Pulled the copper seat out & it looked good. Researched some on the interweb & found one of Duane's posts about the issue, changed the two little orings on the copper seat & BINGO, machine starts & dies like a new one!Duane - you saved the day again!
Reply:I have no recollection of the referenced posts but glad to hear you got the issue resolved.
MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Well it was from 2011, you have slept since then!
GMT+8, 2025-12-18 12:39 , Processed in 0.099666 second(s), 19 queries .
