Sheldon Machine "Quick Change Gear Lathe" ESWQ 56"
发表于 2022-8-7 15:51:42 | 显示全部楼层 |阅读模式
Dream Team,Long story short: I was given the option to receive a Sheldon Lathe with a 56" bed. It is very old.  Best I can tell it is from the 1940s.  Unfortunately, it is in my aunts basement, so it will not be easy to get anywhere.  It has about a half dozen chucks of various sizes and bits, etc.The question: is this machine worth my time and effort to tear down, remove from the basement and reassemble?  I am just a hobbyist fabricator.  Also, what do you think it would be worth?Thanks,Seth
Reply:If it was offered to me I'd drag it out of the basement and clean it up and keep it. What it's worth will depend on the real condition of it, where you are and where it is when you try to sell it. I have an old Colchester  probably older than that and without a quick-change gear box and cone pulley drive. Yesterday I machined up a non standard nut 7/8" x 20 thread on it to fit a piece I bought off ebay that was supposed to come with the nut but didn't. A lathe can be handy to have it will depend on what you plan to tackle in the future.  I don't know what the access is like where it is but just in general terms I'd take the legs off and lower it onto a full length wooden skid to move it . It brings the center of gravity down so it is less tippy. Then you can roll it on pieces of pipe or shaft. Have fun.---Meltedmetal
Originally Posted by Canoecruiser
If it's in decent shape it's definitely worth some pain to get it IMO.  Having extra chucks, collets, cutters, etc. brings the price up a significant amount.  The quick-change gearbox instead of loose gear wheels also is a plus.  From what I've seen the older lathes sell to hobbyists and at least in the Mid-Atlantic, the smaller ones like South Bend 9 and 10 inch, or similar Atlas seem to sell faster and that puts downward pressure on prices of the larger ones like the soon-to-be-yours lathe.  With the stupid prices in the Baltimore/DC area that lathe could fetch ~$2k to $2.5k without much trouble.  Location location location matters....it would go for less 100 miles from DC in any direction.  Clean, rust-free and no evident tool crashes or damage from ham-fisted use moves the price up.This link has a lot of good info in figuring out what you have: http://www.lathes.co.uk/sheldon/If you post your location, someone familiar with the situation in your area could give you better guidance.
Reply:It looks to be about a 12" swing. The long bed is very desirable. If it has a lot of tooling and a steady rest it would be worth about $2000 around me. I am in wisconsin.   The gun smiths like the long bed.  If you do not have a lathe in your shop it would be a good addition. I make stuff on mine all the time.  I just upgraded last year to a 17" swing lathe and it has already paid for itself with no problem.  Mine had no tooling at all. The tooling cost me as much as I paid for the lathe.  I paid $1500 for my 17" but it does not have the long bed like yours. Mine is only a 36" bed.  They start getting cheaper to buy when they get much over 1000 lbs. My 17" weighes in at 3200 lbs . I sold an old South Bend heavy 10 with a 20" bed last year for $750 .Look at the motor HP. That will tell you how solid the lathe is. If it is 3hp or more it is a very solid lathe but is also not a toy . If you get snagged up in it it will not stop until it has done some serious damage.
Reply:Have one just like it!Get it and keep it.From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:I have a Sheldon 13" x 48" made in 1952.  It has served me well now for 3 years.  Sheldon's are solid American iron, well built and accurate.  There is a Sheldon's group on yahoo that I encourage you to join.  John Knox is a former employee at Sheldon and as such is a great resource for information on these lathes.I would keep it.
Reply:2 strong backs and an afternoon. It'll be wherever you want it. Go for it. It'll make a great addition to anybody's shop!But.... What's that funny-looking thing sitting on the headstock?Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW2018 O/A (complete kit)
Originally Posted by lakedrum03
That is the "Bat Phone."  Direct Connection to tech support.
Reply:Alright...... you guys have talked me into it.  Really had to twist my arm.
Reply:If anyone gave me a lathe I would take it!Welders: IdealArc AC/DC 250            Lincoln AC 225 converted to AC/DC            O/A torches            Lots of Hammers Clamps and Grinders
Reply:Hey guys, I am reviving this thread, as I have to move this lathe from out of my uncles basement.  How in the world am I going to get this up a set of stairs?  Does it all come apart?
Reply:Sure, it comes apart.  Just make sure to get a digital camera, and take pictures of every teardown operation you perform.  I mean DETAILED MULTI ANGLE PICS whenever you remove a component...….prior to, and after removal.Headstock comes off.  QC gearbox comes off.  Saddle, and apron comes off.  You can strip it down to the bed.Build a wooden sled, or something with a metal bottom, that slides easily.  Then using the doorway at the head of the stairs, or something else that'll anchor a winch...….winch it up the stairs.  4x4 piece of lumber across the doorway is good for a winch anchor, although you'll run out of room when you top the stairs.  Then ya gotta find something else to attach to.  Even consider running anchor cable/rope/chain from another room.  Or get a good rope, and your buddies, and just pull it up the stairs.
Reply:My first thought was to drag it up the steps over a ramp.  I would try to get it out in 2 parts.  Base and lathe. Minus all the removable stuff like Chuck, crosslide,  tail stock...  I wouldn't be keen on separating the head unless I absolutely had to. Lathe are extremely unbalancedWhat is then status of the steps,  can they be removed?A duct lift might be a option. If weight capacity will match and you can get it down there.Last edited by tapwelder; 10-03-2019 at 05:53 PM.
Reply:2x12s cut to length to lay over stairs top to bottom. Make a sled out of 10 ga. with the nose rolled up like a bobsled. weld a pulling ring in each corner in front and have the width wide enough to weld rings on the sides to strap the bed down tight. Legs, tail stock and chuck taken off.
Reply:Value, where is, is negative.  You are in a used machine tool Utopia.  You will be doing your aunt a big favor getting it out of her house.  It will be a useful piece once installed in your shed.
Reply:It's an old fashioned American made machine, the headstock is probably mounted on the bed ways.  Alignment depends on the ways, not any adjustments on the base of the casting.  So, it's safe to remove the headstock.  It should line up fine when re-installed.All the Chines lathes have adjustable headstocks, which makes it a bit hard to re-align them.
Reply:he got it in there somehow it will come out the same way figure out a weight if its under a 1000 lbs  just the lathe unmounted use a refrigerator dolly and stand it on end.and 3 tough guys.  I helped pull one out of a basement that had a 90 degree bend in the stairs we built a skid for under the lathe then a track down the stairs then just rolled it up the ramp on rollers with the help of a 4X6 crossed the top of the stairs and a com-a-long. just make sure you are pulling against studs not drywall.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:Thanks for all of the help.  I am heading over there on Sunday to start this operation.
Reply:While removing some of the above mentioned items, include removing the motor.  Definitely remove the tailstock, I've been there.  Bob
Reply:Started the clean out yesterday.  Here are some photos of the first load of of stuff.  There is so much tooling that you couldn't use it in multiple life times.Attachment 1706029
Reply:More photos.
Reply:That oven is going to open up a whole new world for you.  Be able to harden, anneal, etc...…………………  You've come into a real treasure trove.  And, you can think about the previous owner while using it.  That means a lot.
Reply:You are a lucky man.  Work slow and carefully.You might want to lose the crocs for some steel toes.  Jest sayin.
Reply:You got you a table top shaper too?either you LIKE BACON or you're WRONG!!!! "There are three kinds of men.The ones that learn by readin'.The few who learn by observation.The rest of them have to pee on the electric fence for themselves"-Will Rogers
Reply:There is a LOT of stuff in that basement! That drill looks great from here, and as someone stated, the oven is cool... if you ever wander into knifemaking, you will certainly appreciate it.Mikel
Reply:That's one heck of a find!  That version is the 11.25" swing model.  With the long bed and with the cabinet it's going to be close to 2,000lbs.  I have a 13" Sheldon with the long bed and it's much heavier than I expected.  Sheldon lathes were considered the smallest of the true commercial lathes and the biggest of the homeowner lathes and were often favored by gunsmiths.A 10" Sheldon is far heavier than something like a South Bend Heavy 10...not really in the same ballpark.I paid $1K for mine, drove three hours each way to get it and felt like I stole it!  The seller listed it on FB Marketplace and I was lucky enough to be the first to contact him and set up a time to get it the next morning.  He said he had a half dozen people trying to get him to sell it before I got there, so I'm pretty sure the price was more than fair.  Yours has a lot more tooling than mine....makes a big difference.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:Hey guys - I have decided to sell this lathe and the tooling to go with it.  I also have a new motor still in the box.  Nothing wrong with the old one and it still runs fine.$1,500, pick up in Uniontown, OH
GMT+8, 2025-12-18 09:29 , Processed in 0.089098 second(s), 18 queries .
