查看: 13|回复: 0
Wher to get RG65 1/16 or less rods
发表于 2022-8-7 15:51:39 | 显示全部楼层 |阅读模式
Hello,Anyone know a source for 1/16 or less RG65 filler rods?Thanks,m
Reply:It a oods rod I work with AWS specs.You may want to look at E70S-6. I like this rod for torch work.Dave
Reply:Airgas says they have 1/16 in stock.Please, Share what you are doing, if you are welding.You can use tig rodLast edited by tapwelder; 1 Week Ago at 03:29 PM.
Originally Posted by Oldiron2
It might be easier to give local suggestions if your location were shown. I know people in New Zealand who need to drive miles just to get groceries, let alone anything difficult like equipment parts and such, so couldn't even begin to offer suggestions there. Yes, it this for use as welding rod, or something else like wire sculpturing?
Reply:Are you Acetylene welding, or TIG welding?An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Sounds like aircraft work. Dave
Location is mid Texas, USA.  Need to weld a relatively lightly loaded critical component in .035 wall 4130.  Pretty much a butt weld of two sections of 1 1/8 od tubing.Regards,m
Reply:If you are going to try to TIG 0.035" wall anything with 1/16" filler, you're in for a rude awakening. More like 0.030"  ER70S-2.  Can be bought by the pound from weldingsupply.com.
Reply:Pannier racks?
Reply:The info I found it is a rod for torch work made in Italy 🇮🇹On Amazon it shows for Tig Welding tooDave
Reply:FYI About this itemRG-65 copper free rod used for high speed fusion welding of pressure vessels, tanks and pipe, All position weldingNew proprietary copper free finish for long shelf life and lower fume emission, Cut lengths made from high quality steelAWS grade and size are embossed on both ends for full traceabilityMade in Italy from the finest quality materials using state of the art technology under highly respected labor conditions
Reply:It looks like RG60 and RG45 or ER70S-6 or ER70S-2 Mig/Tig rod have been used if you can't find O/A rods. ER70S-3 Mig wire has also been used. Yes, you probably want smaller than 1/16" rods. Some (Tig) rods come in .045". Don't know where you're located but see if there is a specialized welding supplier or have the local welding supply contact Techalloy (a division of Lincoln). They have many specialized rods and excellent customer service when I've talked to them in the past. They even found the Certs. for electrodes that were several years old which saved some critical welding, in petrochemical facility, from having to be redone because they couldn't provide the certs.(MTR's). Saballoy below specializes in finding and providing specialty rods. They could likely help you source the rods or suggest who else might be able to. http://www.saballoy.com/Last edited by Welder Dave; 1 Week Ago at 01:59 AM.
Reply:I'd like to thank everyone for offering suggestions here - it has been very helpful.I'd like to apologize for not having enough e's in the title.Regards,m
Reply:Both have their shortcomings. Steel changes shape after it is welded. You heat steel to weld it, it is mostly relaxed when part of a piece is welded. The weld filler, as a near liquid takes whatever shape it wants. As it cools, the not molten steel shrinks, & the weld filler solidifies & it too shrinks. A lot of tension builds up pulling against the portion that never was hot, therefore expanded. Very rigid pieces, the new weld is forced to stretch to conform with the shape it wants to be. Thinner weldments distort from the tension.The less heat the weld process puts into the steel, the less distortion. I prefer acetylene/oxygen welding over TIG, but rarely use it anymore because of increased distortion. In either process, you have to use hammer & dolly to expand the heat affected zone back to size.I believe TIG filler will work well with flame welding. It has been decades since I bought RG, & the memory banks are vague. I believe I used RG45 for all body work. Not sure I've ever heard of RG65.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Everyone has learning on posting 📫. The rod is a odd type for most here My in town  suppliers do not have that rod . They stock mostly cut rods E70S-6. Dave
Reply:I think aircraft. I know other places use the tubing.  Dave
Originally Posted by nickel_city_fab
That, or motorcycles. Its a common frame tubing size.
GMT+8, 2025-12-18 10:19 , Processed in 0.088181 second(s), 18 queries .
