Will a Spoolmate 100 work with a WC-24
发表于 2022-8-7 15:51:39 | 显示全部楼层 |阅读模式
I recently bought a Miller XMT 304 and it came with a Spoolmate 100. I was wondering if I could simply get a WC-24 to run it. Also, if anyone has a WC-24 they would be willing to sell I am interested. I’m 15 and I want to get more into welding but don’t want to spend a ton. Thanks
Reply:Negative on the Spoolmate 100 with WC-24.  The Spoolmate 100 is a direct connect for the Millermatic® 140/180/211/212 and Passport® Plus.The Spoolmatic 15A and 30A guns connect to the WC-24 to adapt to a number of machines and are a direct connect to various others.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:James,Duane's reply is spot on.Here is a Miller link for spool gun compatibility:Spool Gun Hookup Chart | MillerWeldshttp://www.millerwelds.com/support/s...n-hookup-chartSorry if the links do not work...  but if you cut and past the above, it will get you some good information.Welcome to the group.  There are some amazing people here who are willing to share a wealth of information.Geoff
Reply:You probably wouldn't be happy with a Spoolmate 100 anyway. A 15A or 30A is only about 8 to 10 times the cost. An XMT 304 is a very good machine though. Did it come with a wire feeder?
Reply:James0123  is 15 years old by the looks. He has the Spoolmate 100, it was included with the XMT 304,  If he could find a SGA 100C he could probably make that work but it might not be plug and play. I saw a new one on Ebay $803.00 USD so not likely practical for him.---Meltedmetal
Reply:Thanks everyone for the support. Welder Dave, it did not come with a wire feeder. Also, would any of you recommend a spoolmatic 3 for my machine. I saw one on eBay for $1100 and don’t know if that is a common price. If it is, I’m probably not going to go that route.
Reply:PM me, I have a 3 that I bought to use on my xmt that I don't really use much.
GMT+8, 2025-12-18 10:45 , Processed in 0.056513 second(s), 18 queries .
