查看: 13|回复: 0
ESAB em215ic part identification
发表于 2022-7-26 15:51:24 | 显示全部楼层 |阅读模式
This welder does not power on and looking at a thermal image I'm seeing the hotspot on R79. The cap comes off pretty easily and under it is a disc made of some type of conductive material. Does anyone know what this part is and what is it's function? How much current should I be measuring for at this component?Any help would be wonderful.Regards,
Bryan
Reply:Did you check the voltage coming out transformer in photo.Most time with electronics it is transformer or rectifier that dies.Dave
Bryan
Reply:I'm not sure if power has reached the transformer at this point? Does ESAB provide a more in depth manual for this?
GMT+8, 2025-12-18 09:30 , Processed in 0.141255 second(s), 18 queries .
