Capacitor help
发表于 2022-7-26 15:51:23 | 显示全部楼层 |阅读模式
I am looking for a capacitor for a Miller bobcat 225The capacitorAweoMMade in the USAType CGR1000MFD 75VDCPos + 85cMax surge 100VDC123-849-677-9120162That is the information on the capacitor does anybody know where a guy could find one of them
Reply:Here is one Is it 1,000 or 10,000 mfd?https://www.mouser.com/ProductDetail...h8uWTI4TZmade?FYI  It is easier just goto 100 volt than find one with 100 volt Max surgeDave
Reply:It is a 1000 mfd
Reply:You can find that size on Amazon too.I would look for 1,000 mfd 100volts It makes looking simpler and will run cooler too.Dave
It is a 1000 mfd
Reply:Okay thanks I'll go try Amazon and that site I've got to post going but I replaced the sr2 and still know weld output or AC output and no DC voltage at brushes but when I took the wires off of the capacitor it quit blowing fuses on f2 so that is telling me that the capacitor is bad correct or am I wrong I started it for a few minutes to see if I got AC power back which I do but I did not check the weld output
Reply:Given the choice of Mouser or Amazon, I'd go Mouser . . . Amazon has far too much counterfeit/offshore crap, vs Mouser being a reputanle supplier.
Reply:You didn't post a picture or list sizes, so we don't know what might not fit...but if you want the 100v rated one and an 85* rating, here's one that fits:https://www.tedss.com/Capacitors/Bro...temperature=85If 75v ones suffice, or are needed by being shorter, than these can be chosen from:https://www.tedss.com/Capacitors/Bro...temperature=85This is a reputable suppler, sometimes referenced on site when members need capacitors.
GMT+8, 2025-12-17 10:55 , Processed in 0.181805 second(s), 18 queries .
