Spool Gun Wire Feed Speed Settings
发表于 2022-7-26 15:51:22 | 显示全部楼层 |阅读模式
Good Morning all,I was hoping some spool gun veterans would be able to share their wire feed speed settings for different joints (1/8th Aluminum 5052)1. Inside fillet joint wire speed?2. Butt Weld wire speed?3. Inside fillet TACK wire speed?4. Butt Weld TACK wire speed?5. Outside corner TACK wire speed? I have settings for all of these but was wanting to compare my settings to some expert settings, Thanks guys!
Reply:I don't mig Aluminum, but I suspect that your settings are going to be pretty close to anyone's that is using a spool gun, your voltage and wire speed will work together depending on operator skill and welding speed. different machines will also have an effect on it. There is no "one & done".NRA LIFE MEMBERUNITWELD 175 AMP 3 IN1 DCMIDSTATES 300 AMP AC MACHINELET'S GO BRANDON!"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.” BENJAMIN FRANKLIN
GMT+8, 2025-12-18 09:25 , Processed in 0.064242 second(s), 18 queries .
