Everlast 210EXT New machine first run?
发表于 2022-7-25 15:51:24 | 显示全部楼层 |阅读模式
I just ordered a new Everlast 210EXT and was wondering if anyone has any suggestions on how I should start it up.Can I run it full power out of the box, or should I run lower amps a few minutes before turning it up?Thanks This machine is to replace a Lincoln Square Wave 200 which is at the service center waiting to be diagnosed.
Reply:Unless the manual explicitly stated that you have to "break it in", I dont see any reason why you can't use it for what it was intended.
GMT+8, 2025-12-18 08:56 , Processed in 0.092322 second(s), 18 queries .
