So I saw another old Hobart generator welder....
发表于 2022-7-25 15:51:24 | 显示全部楼层 |阅读模式
https://www.facebook.com/marketplace...c-ef0a14dfae6fThis one is run on propane.Any problems or insights into this model of welder?Any difficulty converting it back to gasoline?  OR can you set it up to do both and go back and forth?Last edited by ericsarratt; 20 Hours Ago at 07:38 AM.
Reply:It is just getting a gasoline carburetor. Typically the regular needs to rebuild on propane carburetor.Dave
Reply:I see its a Dodge 6 cylinder. I bet its a hog on gas. Propane was cheaper last time i checked. This one is 300 amps and looks like DC. Cant say for sure about the outlet but if its like an SA200, its DC. Tools run like a bat outa Hell on DC. Some tools dont like DC and dont use variable speed on DC unless wide open.
Reply:Thanks for the information, and for the information on propane.
GMT+8, 2025-12-17 10:54 , Processed in 0.292814 second(s), 18 queries .
