查看: 14|回复: 0
So I saw this old Hobart generator welder....
发表于 2022-7-24 15:51:40 | 显示全部楼层 |阅读模式
https://www.facebook.com/marketplace...c-73ad10673c66What is this?Is it worth investigating?I do like old stuff.
Reply:It is a Hobart 213 It is great welder for stick welding. It has a 120 volt DC plug.Dave
Reply:The guy says the carburetor is missing.  How difficult is it to find a carb for an old Wisconsin engine?He said his grandfather took the carb off to repair it then never got around to it.
Reply:Tractor salvage yard has most parts even the engine. Dave
Reply:Thanks!  I also found a running used engine for $250.
Reply:I would buy that welder for the novelty of taking it apart,, if nothing else,, at that price.Heck, the two car batteries would give you back over 10% of your purchase price when you scrap them,,If the machine welds,, you would have the buy of the decade,, as far as welding machines go,, there are so many eBay import new carbs for less than $15,, something should work, if nothing more than to test the engine.
Reply:Its great if you are a junk collector, if you want to weld get something modern.www.urkafarms.com
Reply:A friend of mine had what I think was a similar welder(looked similar). It welded beautifully, but he had a problem with the throttle linkage adjustment. I think hesold it without ever getting the issue sorted out.If you’re going to adapt a carburetor, you might havesome headaches if you want throttle mechanism towork properly. For $150, I’d buy it, but I like old stuff.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Anybody know what type of carburetor is on a G-213?
Originally Posted by Insaneride
Did you find a TJD or THD? Either would fit but the magnetos are different in firing order. Parts are expensive for those old WISCONSINs. $250 is not a bad price if it runs but then theres the welder thats going to need money.
Reply:My mistake.  The welder is a Hobart G-213 (I think).  That makes the motor a Wisconsin TJD.  The owner is confirming the model number for me today, but I think I'm going to just pull the trigger.  I bet I can get it working for under $300 (welder + carb).
I thought it was a WISCO motor. Whats G-213?That motor looks like electric start THD or TJDI think theres a couple versions of carbs for those, I have a couple and one has a manual prime. I may have a spare, I will check when the sun comes up.
Reply:I have one and it welds great. Dave, mine has 120v AC. The fine amp knob is missing but you could probably adapt another to it. I have the engine and welder manuals. PM me  your email add and I'll email them to you. With the 2 batts in series it cranks via windings in the welder and if they're connected backward it will still crank but will draw the batts down. Ask me how I know.Last edited by mla2ofus; 19 Hours Ago at 08:46 AM.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:This thread https://weldingweb.com/vbb/threads/7...rt-g213-welderhas good info. In post #8 forhire has links about the ZENITH carb.
I am curious.  When you say "it welds great".  Is it smooth like a more modern welder?If it is still available.  I'll hit you up for the manuals.  I messaged a few times with the seller last night.
Reply:The Hobart 213 is very smooth welder. Dave
I will bet it welds every bit as smooth as a SA200.
Reply:On that carb...When I google "Zenith series 68" it pulls up carburetors on Ebay for $80 and carburetors on Amazon and private sites for $400--that don't look any different.Is there any difference between these carburetors or is that just people jacking up the price?Last edited by ericsarratt; 17 Hours Ago at 10:20 AM.
The Hobart 213 is very smooth welder. DaveI like welder I had a new one in 1978 and it was a great welder. 👍 Dave
Nice.  Good, cheap, smooth welder.  It is hard to go wrong for 150 bucks.
Dave, did you mean 120v AC?And by "great welder for stick welding"--you mean it is smooth?   I am new to welding so I ask some newbie questions.
120vdc was pretty common. Good for most old brush type power tools and resistance devices. Deadly to other stuff.
Reply:It is DC for 120 volts.Everything had to be rated for DC.It was the only down side but all my tools was DC ratedDave
Reply:Must later version. Mind was 120 DC and would liked AC.Dave
Maybe your's was DC but mine says 120v 60hz on the data plate. Don't know about tyhis one but if you buy it be careful not to overload the AC circuit rated at 3k watts as it will burn out the windings easily.
Reply:The seller never showed up.  I sat at the address he gave me for an hour.  During that time I received multiple texts from him saying that he would be there in a few minutes or that he was on his way, etc.  Finally, I realized that no matter what the texts said he was not going to show up.Weird.Not sure what kind of thing goes on in people's heads or why they play games like this.I just don't get it or see the payoff.I didn't text him bad things or call him and curse him out.Just moving along.Last edited by ericsarratt; 5 Hours Ago at 09:55 PM.
Reply:I have had a few of that type in pass mainly selling.Dave
GMT+8, 2025-12-18 08:57 , Processed in 0.095691 second(s), 18 queries .
