C02 with flux core
发表于 2022-7-24 15:51:40 | 显示全部楼层 |阅读模式
Got the see a bud use his setup. He uses C02 with flux core. Seems to have less splatter cleaner looking welds.  Is that a normal practice?Retired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:I used E71T-1 with CO2 for over 20 years .  Works Great 👍  .Today I use E71T-11 no gasDave
Reply:Not all types of flux core can or should be used with shielding gas. Using shielding gas with wire designed to be self shielding will make the welds brittle. Dual shield wires (fcaw-g) used with shielding gas are wonderful. Like a continuous spool of 7018 electrode.
Reply:FYI: E71T-1 the flux will fall off as the weld cools 😎.  Dave
Originally Posted by Oscar
You haven't specified if he is using gas-less flux core wire, OR gas-shielded flux core wire.  The latter needs CO₂ (or sometimes an argon-CO₂ mix), the former should not use any shielding gas.Page 21, Lincoln FCAW-S (Self shielded Flux core arc welding) Guide is what I recommend you read.
Reply:Ok gang he is using  E71T-1/1M X .035 he was welding 3/8” thick material Retired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:I use everything to AWS Standards only. Lincoln was aways a higher price than any other brand.I used E71T-1 with CO2 it work best.I purchased 5 at time in 60 pound coils at time for best price or 300 pound. Dave
I will shoot him a txt and ask. He said it was flus core but I didn’t ask what type.
Reply:Im not buying any, not anytime soon.  That stuff is expensive and gas too, nope.  If I need to stick some thick stuff then I will burn rodsRetired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:Sounds great to me.I still have rods but all my welding today is with E71T-11 0.030". The best price is from Amazon or Walmart.  Dave
GMT+8, 2025-12-18 13:53 , Processed in 0.058814 second(s), 18 queries .
