Vulcan Protig 205 Hand Amperage Tig Torch
发表于 2022-7-20 15:51:30 | 显示全部楼层 |阅读模式
Does anybody know of a hand amperage torch that is compatible with the harbor freight protig 205? Im looking for something that is just a button for on/off, no variable amperage, just a simple 2T hand amperage torch, need to get into some awkward positions on my metal boat, thanks for the assistance!!
Reply:I am satisfied with my touch4 from ssc.  Needs to be within 33 percent of your max, then you have 4 increment of increase.  The movement is almost imperceptible, but not overly sensitive. Not sure it is compatible with your, though it does not list it as a no-go.
Reply:So you're calling it an "amperage switch", but you just want it to be On/Off ~ right?That means you could buy a simple switch (purpose made, Google "Tig Switch") for less than $5 and run the two wires down the cable and connect to the pedal connector on your machine (you'd have to research what 2 pins need to go to it, but that's easy enough I'm sure...)
Reply:Not sure what the connector is on the machine now.  One way if your friendly to and handy with minor modifications.
Wire one of these 2 wire jacks to the contactor trigger wires in the machine going to the existing connector.https://www.amazon.com/Aviation-GX16.../dp/B06Y6MQTPDhttps://www.ebay.com/itm/15481063389...Bk9SR8rQ2-_CYA
Reply:This is exactly what I was looking for thank you for the insight!
Reply:Im going to try this out forsure thank you for the clear and easy to understand explanation!
GMT+8, 2025-12-18 13:52 , Processed in 0.086791 second(s), 18 queries .
