small stainless weld help
发表于 2022-7-20 15:51:30 | 显示全部楼层 |阅读模式
What am I doing wrong on this weld.  Stainless with 98/2co2, yes it is on wood because I use that to prevent contamination.  I do all my wire brushing on plywood on the table.  Tried pulsed spray for the first time on this and looks like I don't have it dialed in all the way yet.
Reply:I see a rod welded to a washer in the picture.  Is that not what you were trying to do?   If that is what you were trying to do, what is wrong that you see with those welds, or what?   Not exactly sure why you're asking what you're doing wrong.
Reply:Judging from the BBs I reckon This is Mig??It does have a strange look to it, but it looks like good penetration.  Is that silver spray paint or just the picture?What exactly are you Making or repairing?
Reply:Trimix wasn't used which would account for the discoloration
Reply:I agree 👍 Something are just easier with TIG. Dave
Originally Posted by Willie B
Stainless MIG needs tri mix gas one side to weld, other side needs argon shielding. The discoloration, I'd guess was wrong gas, and/or wrong filler. At risk of sounding too much like someone else, TIG would be the better process.
the little beads look kind of hanky with the folds in there,  I did not think that looks right.
Reply:They are tack welds and look to be pretty hot so you're going to get a bigger crater. The finish on the washer may be contributing to the odd looking craters.
GMT+8, 2025-12-18 13:56 , Processed in 0.090114 second(s), 18 queries .
