Lincoln Idealarc TIG 300/300 with Wire Feeder Question
发表于 2022-7-19 15:51:22 | 显示全部楼层 |阅读模式
I have an old Idealarc 300 welder, and was wondering can a Miller S-52E wire feeder be used with it?
Reply:Basic answer is no but I am sure someo0ne can find a way to cobble it on.www.urkafarms.com
Reply:I'm guessing maybe a cable adapter could be made up to go from the 4pin to a 5pin connector on the welder.
Reply:No it won't work. that wire feeder requires a constant voltage power source and the Lincoln TIG 300/300 is a constant current power source. You MIGHT be able to hook up a voltage sensing feeder to the Lincoln, but the Miller S52 isn't the right feeder for that.Miller Multimatic 255
Reply:Smoking fingers Louie!Beat me to the answer.
Reply:Ok, thanks for the quick reply.
GMT+8, 2025-12-18 09:53 , Processed in 0.105424 second(s), 18 queries .
