Need to know connector name
发表于 2022-7-15 15:51:58 | 显示全部楼层 |阅读模式
I need a connector like a rivet, but so the 2 pieces are not tight but can swivel around the rivet. I have seen connections like that but don’t know what they are called. The 2 pieces need to be tight enough to not wobble but smoothly rotate. Also this is for a manufactured product so needs to be efficient to make. Is it some kind of welded shoulder bolt or special rivet that doesn’t completely clamp down? Any information or direction is appreciated.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 120www.10FtDrillBit.comwww.MyWelds.com - pictures of my work
Reply:Chicago bolts or Sex bolts.https://www.google.com/search?q=chic...h=955&biw=1288https://www.google.com/search?q=sex+...&bih=955&dpr=1Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Originally Posted by wb4rt
Thanks for the quick response. I need this joint to be permanent and not able to unscrew. Not sure if there is a locking type of these or a spot welded type.
Reply:I agree 👍 I used RED Loctite on morse drill chuck when about 15 years old. It took a torch to remove the drill chuck for drill press. I only did that one time never again. Now I only use for bolts I never want to remove. Dave
They have locking sex/Chicago bolts or use Loctite, Blue or Red, Blue is strong and will come off with hand tools, Red is more permanent and requires 400º+ heat applied to it to break it loose.
GMT+8, 2025-12-18 08:58 , Processed in 0.109936 second(s), 18 queries .
