Does any refurb motherboards?
发表于 2022-7-13 15:51:27 | 显示全部楼层 |阅读模式
It seems like the go-to around the 'nets/shops is to just 'replace power board'.I inspected a Hypertherm Powermax 30 XP for a friend and found that the "TOP247YN" was literally blown up and one of the legs went with it too. I soldered in a new one (everything else looked OK) and it's still not showing any signs of life (no LEDs light up when switched on). Does anyone know what it would take to refurbish theses motherboards?
Reply:You can try here:https://innovatcorp.com/pc_board_repair_price_listBut a few years ago I needed a board for a Powermax 45 and they didn't have it because hypertherm does not release the schematics or something to that effect.  Not sure if that has changed.  I ended up getting a replacement board from hyper but it was like pulling teeth.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I use Windows XP on Windows 11 64 bit using a Vbox. There are programs I use that is 16 bit .Dave
Reply:Looks great
Originally Posted by psacustomcreations
I drive a Ford F150. That is what I use to go places. Sent from my SM-G996U using Tapatalk
Reply:I work 60 year no hobby welder Some here go youtube is true I weld overhead outside no hot is yesMiller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:It is a program inside your computer that runs older operating systems on Windows 10 and 11. Some will go back to systems of the 1950's. This one I use the price great FREEhttps://www.virtualbox.org/Dave
Reply:Somehow these guys come to mind.
Ernie F.
Reply:Well, I still love cheese, so there's that.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:Yall have gotten kinda mean
Sent from my Lincoln Buzzbox using Tapatalk
Reply:If Powermax 30 XP has nothing to do with computer mothers.There are guy repairs old industry board.  But they charge a lot. Odds are it is switch if newer it could a battery most time it is CR2032. If so it could loss programing. If loss programing you find places that will reprogram for $200.00 and up.Dave
Reply:Also... ain't as good as the real thing, but I guess a virtual box is better than nothing.
GMT+8, 2025-12-18 10:24 , Processed in 0.165834 second(s), 18 queries .
