查看: 14|回复: 0
Cordless Grinder Acquisition
发表于 2022-7-13 15:51:27 | 显示全部楼层 |阅读模式
I already have 3 corded grinders, a Porter Cable, Dewalt and Milwaukee.   I picked up a Milwaukee model 2880-20 cordless 18v unit yesterday.  Just fidgeting with it after getting home, I think I'm gonna like it.   Good balance and power for a cordless, and uses the same battery packs my other Milwaukee tools use, which I have about 10 extras, if needed.
Miller Multimatic 215Miller Spoolmate 150Primeweld cut 60 Plasma CutterMilwaukee Chop SawBauer Portaband Saw w/Swag TableDewalt, Milwaukee, Porter Cable 4.5” grindersMag Drill/Annular CuttersArcUnion J-20 Portable Rod OvenVevor pipe stands
Reply:I have probably the identical tool,,it is "nice" as it is cordless,, but, the speed is WAY slow compared to a Milwaukee or Makita corded.So, despite having plenty of batteries,, when I need a "real" angle grinder, I drag out a corded one,,,
Reply:Dewalt grinder speed are dictated by battery size. I only use it in the field but no complaints.  Does Milwaukee have thatFeature?
Reply:I have a couple of those cordless Milwaukee grinders, and all sorts of name brand corded grinders. Those cordless are my go to and hang on my tripod at the arc. I run one with a saucer twisted knot and the other with a 27 grit Walter. Can't beat them the less cords in the way the better. And with fuel prices the way they are, the less I have to run the welder the better.
Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:I think it will be very  useful with a wire wheel on it for cleaning slag off the weld, and doing some rust removal if needed.Miller Multimatic 215Miller Spoolmate 150Primeweld cut 60 Plasma CutterMilwaukee Chop SawBauer Portaband Saw w/Swag TableDewalt, Milwaukee, Porter Cable 4.5” grindersMag Drill/Annular CuttersArcUnion J-20 Portable Rod OvenVevor pipe stands
Originally Posted by 52 Ford
Are you sure that air hose it big enough?
GMT+8, 2025-12-18 10:24 , Processed in 0.052989 second(s), 18 queries .
