Fuel tank build. 2 gallons
发表于 2022-7-12 15:51:26 | 显示全部楼层 |阅读模式
thats 2 gallons of water. Picked a rod up with wood oil on it that I contaminated touch of the inside with. Got about 3 hours Into it. Any opinions are welcome.
Reply:What’s the best way that you have found to get to the inside corners?  Do you start at the corner and work out?  I always seem to dip my rod into the tungsten when close to the corners and have to resort to the spool gun which then looks like crap.  No constructive criticism from me, looks good motoMiller 350 DynastyMiller TrailblazerMiller 625 Plasma Died and needs a new circuit board so its an expensive boat anchor nowLincoln Power MIGVictor oxy/acetyleneHyperthem 85
Reply:Start on either side. Had to go left handed a couple times. Sounds good John… you’re ok man
Reply:Gasoline will leak where water won't.Pressure testing with just a couple PSI and checking seams with soapy water would be much better IMO.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I was just seeing what it will hold. I’ll definitely pressure test it
Reply:Oh my god...you've made a bomb!
Are you crazy?Before you finish it - think about the poor bus full of nuns bringing puppies to the orphans that you'll kill with that thing.
Looks ok
Inside corners are tricky - looks like good practice for it.....bomb...flaming death....oh the humanity....
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-18 08:59 , Processed in 0.091034 second(s), 18 queries .
