查看: 13|回复: 0
Chop saw Station on my Workbench with a turntable - Looking for Design Ideas
发表于 2022-7-12 15:51:26 | 显示全部楼层 |阅读模式
My shop is only 20x20, so efficiency of space is always a premium for me.  I've got a little 6' x 2' workbench that I also use as a cutting station for my dry cut saw.  I've been thinking about devising a way to put a turntable in one end of the the bench top...so I can make miter cuts without needing to pull the table out to the center of the shop every time I need to miter-cut something.I don't have the space to build a dedicated chop say station from scratch - so I'm trying to make this work instead.  If any of you have built a stand/table/bench with a carousel or turntable in it for chop saw miter cuts, would you mind posting pics and/or describing for me how you built it?  I probably wouldn't be opposed to buying a turntable or carousel if necessary, but I always try to figure out if I can fabricate something myself before I spend money on something I could have built myself...Here's what the current workbench looks like - with the saw - in the space I have to work with.
Thanks!Red
God bless our military men and women and their families!  To all our veterans and active duty military...Thank You For Your Service!Hobart Handler 210 MVP
Reply:I would locate saw just to right of bench so you could use bench as a feed table. At point you could make a turntable for saw.Dave
Thanks!Red
Reply:There was a post on this not long ago try a search there were some awesome buildsRetired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:Look here https://weldingweb.com/vbb/threads/7...etal-saw/page2Retired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
GMT+8, 2025-12-18 10:24 , Processed in 0.094652 second(s), 18 queries .
