查看: 14|回复: 0
Millermatic 30A feeder connection to MM200 and drive roll conversion?
发表于 2022-7-9 15:51:40 | 显示全部楼层 |阅读模式
I'm picking up a Millermatic 30A to run off one of my MM 200s(white face 81)My goal is to set it up for aluminum Can I get the 110 to run it off the machine?Will a standard miller gun work?How can I convert to the common Miller drive rolls? It has 0.035 V and I want to run 0.047 and 0.062 U for aluminum
Reply:It looks like the part to connect the gun is missing unfortuneately. Hoping I can make something.
I found this pic on another post on this site.Looks like the part that I'm missing.
Reply:The good news is you need a front set rollers. I used Tweco on my 30A and 30Bs and a 10 foot gun with Teflon liner. .I machine the Tweco adapter so very close to feed rollers about 0.005 gap.Dave
GMT+8, 2025-12-18 09:00 , Processed in 0.083255 second(s), 18 queries .
