Newbie
发表于 2022-7-8 15:51:30 | 显示全部楼层 |阅读模式
Hello, complete newbie on welding here. I would need for a project to butt-weld two very thin sheets of different metals (0.5 mm thickness at most), ideally without a filler material. Do you know if it is at all possible? I was thinking maybe ultrasonic welding could be a possibility.Thank you very much.
Reply:Ok I’m not up on the metric system we used 3/32 6013 on DC 45 amp on some replacement floor boards in a Chevy truck, would have been easier with the MiGRetired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:AND.... how are the metals "different"???
Reply:That is 0.020" or 26gauge that hard to weld. Most would use tig. Dave
GMT+8, 2025-12-18 08:58 , Processed in 0.094140 second(s), 18 queries .
