Champion 10000 won't shutoff
发表于 2022-7-7 15:51:26 | 显示全部楼层 |阅读模式
Welder works as it should. Kohler ch20 engine starts, runs , idles up and down but wont shut off with ignition switch. When switched to off position it goes to high idle!ESAB250w/spool gun attachMillerBobcat 225GMIllerEconotig 150MillerSynchrowave 350LincolnLn25Miller Xtreme 12SHobartMegaArc 300DMillerTrailblazer 44G2004FL70 14'mechanics body14k crane 70cfm compr
Reply:It may be the switch, look at drawing if you have one but I think it shorts it out. I had one on a briggs linc do that a while back.www.urkafarms.com
Originally Posted by 52 Ford
Is high idle integrated into the off switch? Sounds like you have a multiposition rotary switch or toggle switch. Pop the switch out open it up, douse it in CircuitSafe, LectraMotive, or some other electronics cleaner that has a cool name (the cool name is important). Isopropyl alcohol would work, too. The idea being to wash away any contamination and to displace any water that may have made it into the switch. Could be as simple as that.Sent from my Lincoln Buzzbox using Tapatalk
Originally Posted by 12V71
It goes to high idle because the 12 volts have been shut off... Ergo no power to the idle solenoid, the ignition switch probably also incorporates a magneto ground thats not working, I could be wrong but it's worth checking out.
Sounds right to me. Kinda hard to diagnose something over the interwebs with out a lot of detail.
GMT+8, 2025-12-18 08:58 , Processed in 0.093269 second(s), 18 queries .
