Protection for catalytic converter with chain
发表于 2022-7-7 15:51:26 | 显示全部楼层 |阅读模式
So, ive been having problems with thieves stealing the catalytic converter from our warehouse. You can buy plate and such and anchor but they are expensive and i want to do something cheap.My idea is to use GRADE 8 chain and wrap it around  like a snake and weld it directly to the exhaust.My question is what steps would i need to do to make sure it bonds well?Would it be better to use a lower grade chain because GRADE 8 is strong?Do i need a heating element to get the chain hot before i weld it?
Reply:You engineer this by yourself or have help?www.urkafarms.com
Reply:Nothing stops a thief. That chain will add some time to their cut time. Plus that's a lot of weight for the exhaust system to carry.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:Park in a fence with several unsociable dogs. Works for me.
Reply:So the zip wheel they use to cut off the cat won't cut through chain?
Reply:Rock salt in a 12 gauge! Sent from my Lincoln Buzzbox using Tapatalk
GMT+8, 2025-12-18 10:26 , Processed in 0.100216 second(s), 18 queries .
