Help with Miller xtreme
发表于 2022-7-3 15:51:53 | 显示全部楼层 |阅读模式
Hey guys I could use some help if at all possible.I've looked all over but can’t really find any answers to what I’m looking for.  I just bought a used xtreme 12vs and I’m trying to run it off of my bobcat 225. Problem is I’ve got the little bobcat on 10 but I don’t seem to be getting nearly enough heat.im running .45 dual shield with mixed gas and I’m only trying to weld 1/8”the machine is set on wire -positive lead going to the boxground lead going to the work pieceive tried it on wire + and - seemed to do a little better on negative.Seems like I can’t get the needed penetration from what I’ve read seems like that wire wants 22-26v can’t remember the wire speed I’m also having issues figuring the wire setting I’ve got the box on the low setting and the dial on 60any and all help would be greatly appreciated
GMT+8, 2025-12-18 13:35 , Processed in 0.112244 second(s), 18 queries .
