Gas regulators and flow gauges
发表于 2022-7-3 15:51:53 | 显示全部楼层 |阅读模式
Typical regulators I see people using have two pressure gauges and a single stage regulator. The regulated pressure is displaying flow instead of pressure. I assume this is a calculated flow based on tests of typical restrictions a welding torch presents and what pressure is required to give each flow rate. Any threads here on moving to a better rotometer and regulator?I want a duial stage regulator to get consistency over the entire life of the bottle and want to setup a real flow meter.
Reply:I am for hire.
GMT+8, 2025-12-18 10:21 , Processed in 0.086135 second(s), 18 queries .
