Welding Rod For 14ga. Rectangle Tubing
发表于 2022-7-3 15:51:52 | 显示全部楼层 |阅读模式
I'm working on building a mobile base for a SawStop table saw I recently bought!The material I'm using is 14ga. 1" X 3" rectangle tubing & some 1/8" 2" X 2" angle-iron.I've never really had any luck welding thin material, so I would like to know what's the best type & size of rod to use on this 14ga. tubing?
The welder I'm using is an old Marquette I got off of craigs list, I got it cheap since it wasn't working correctly!  I replaced a couple of parts & cleaned it up & it been running great since.There are a few pictures of the welder in this post.https://weldingweb.com/vbb/threads/7...r-To-The-ForumDoug
GMT+8, 2025-12-17 10:54 , Processed in 0.127658 second(s), 18 queries .
