End of spool
发表于 2022-7-1 15:51:25 | 显示全部楼层 |阅读模式
What do you do with the last bit of wire when the spool runs out and it won't feed anymore? Seems too wasteful to me. Who's got the cool diy on what to do with those three feet of wire that you gotta pull out before you load the new spool?
Reply:I use fluxcore it goes in the trash can.If you solid wire it will work for tie wire.Dave
GMT+8, 2025-12-18 13:52 , Processed in 0.057410 second(s), 18 queries .
