PrimeWeld- Cut 60
发表于 2022-6-30 15:51:41 | 显示全部楼层 |阅读模式
Just wanted to share my experience with my Primeweld Cut 60 Plasma Cutter.   I’ve had it 6 months, cut plate, mostly 1/4” but some 3/8” as well as angle iron,  1-1/4” square tube and some other miscellanous steels, and I’ve been very pleased with the performance of the machine and the customer support from PrimeWeld.   Seems to be a high quality machine.   I recently purchased some drag tips for it, but have not used them yet.  The regular tips are used with the stand-off ring on the torch.   The PT60 Temco Torch has a 20 ft. Lead that really rolls up nicely when I want to put it away, and it has a quality ground clamp and lead.   It has continuous pilot arc, and gives good quality cuts, especially when using a straight edge as a guide or a template.   Superb value of quality vs. price IMO.   I got my unit thru Amazon.com, but one can order directly from PrimeWeld also.The unit also comes with a connector to be used with a plasma cutter table, but has to be soldered into the control unit.Last edited by metalmelter2021; 17 Hours Ago at 10:19 AM.
GMT+8, 2025-12-18 09:25 , Processed in 0.065448 second(s), 18 queries .
