Hard surfacing rod for brush cutter
发表于 2022-6-30 15:51:40 | 显示全部楼层 |阅读模式
Can I use a stellate on brush cutter blade ? Use use a oxy acetylene rod the was hard surfaces for repair of end cams .Would the be the way to go on these worn cutters blades What do you think ?
Reply:Buy new blades.If get blade out of balance you destroy your gear box.Dave
Originally Posted by 52 Ford
No. I recommend you do NOT build up blades with hard facing rods. Just use regular filler metal. Those blades are mild steel to begin with so they will yield instead of fracture if you hit something hard. But, I'm not the boss of you. If you so still want to build up the cutting edges with something more wear resistant, go for something that has the ability to yeild. I think Stellite would break and send out shrapnel (shrapnel = bad!
). Sent from my Lincoln Buzzbox using Tapatalk
Reply:I due balancing it takes time to do. Most brush cutters need a Dynamic balancing too. I work in a machine shop where two guys spent 8 hours balancing brush cutters. Dave
Originally Posted by Lis2323
blades can be balanced but i agree.....buy  new blades.
GMT+8, 2025-12-18 13:56 , Processed in 0.166217 second(s), 18 queries .
