New Cyclone 212, MIG/Stick welder with Power set
发表于 2022-6-28 15:51:23 | 显示全部楼层 |阅读模式
Everlast is continuing to add to its new and innovative line of MIG welders.  The new Cyclone 212 is now available.  It comes with a 5 year parts and labor warranty with 3 year shipping coverage on the unit should it need to be shipped for repair.  The unit features MIG and Stick capability with 230A MIG output capability and 160A Stick output Capability.  Duty cycle is 35% @ 200A/160A for MIG/Stick operation.  It has a capacity of a 4" or 8" roll of wire. ( up to 12 lbs).  It supports a spool gun.  It also has the new Powerset function which is easily set up and adjusted.  It can operate on 120V or 240V.  Of course, on 120V, output is reduced.   It also has a flux-cored wire function too.The unit is designed to be compact for portability and storage.  It comes with everything you need to get started except for wire and gas.
Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-18 17:35 , Processed in 0.104589 second(s), 18 queries .
