查看: 13|回复: 0
What to do about metal shavings from chop saw, etc.
发表于 2022-6-28 15:51:22 | 显示全部楼层 |阅读模式
Hi everyone, just got myself a nice chop saw with a tungsten-tipped blade. I knew it would yield coarser shavings than other options, but had an aha/uh-oh moment when I saw them sprayed all over the table & floor in my garage. Most went into the little reservoir they have for them but, as is inevitable, plenty got scattered around. Looks like there’s a port for a vacuum but I can’t imagine it’s a good idea to attach my shop vac to it. There’s a lot less sparking than with a abrasive disc but there are still sparks. Trying to minimize sweeping and vacuuming after use. I was thinking of getting some magnets and sticking them in a few strategic places,though I’m not sure how effective that would be. I’ve also considered some kind of foil shroud. . .Anybody have other ideas?
Reply:Build a saw saw station  over a barrel.  I use a a rolling/ sweeping magnet and a shop vacuum with a dust collector connected to sweep the floor. Nothing gets to the shop vac.
Reply:This is one of the best little gadgets I ever picked up from Harbor freight.  It's a rolling magnet/stickI use it all the time.  Just wheel it around and it's amazing what you will pick up.
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:It was not in shop, it outside with all things messy.I use road base for floor and ran tractor over floor once or twice a year. Dave
Reply:You could pick up one of the cyclone tops, put it on a metal container and run the vacuum thru that. The hot heavy chips fall into the cyclone container and don't go into the vacuum. Still have to be careful with the hoses though.
Reply:This is a fabricators biggest mystery. Tool Junkie has a great suggestion.  Perforated or expanded Sheetmetal top works over a containment box.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Hi everyone, just got myself a nice chop saw with a tungsten-tipped blade. I knew it would yield coarser shavings than other options, but had an aha/uh-oh moment when I saw them sprayed all over the table & floor in my garage. ...Trying to minimize sweeping and vacuuming after use. ...Anybody have other ideas?
GMT+8, 2025-12-18 09:29 , Processed in 0.087207 second(s), 18 queries .
