Linde C-300 Welder
发表于 2022-6-28 15:51:22 | 显示全部楼层 |阅读模式
Guys-The ad is below.  I'm wondering about this welder, can't find much information on it.  guy is askin $1000, looks to be in very good condition.  Is it possible to use this as a power supply also and hook up a mig wire feeder to it?  Sounds like these welders are bullet proof, but big.  What's your overall opinion of something this old?Thanks in advanceTylerLinde C-300 AC/DC Tig or Stick 20” with coverNew 20” ground lead10 gallon water tankMounted on steel cartAll lead and hosesScratch startGood machine, works well.30”wide x37” tallCart is 13” wider than machine and the michine sits in the slot in the cart, with 13” wide spare for mounting bottle. Cart adds 8” to machine height. This is on good heavy duty casters.220 powerMade by Union CarbideThis machine usually sells for between $1500 and $2,000. The torch and ground lead wire has been used once. They are brand new and cost over $300. I paid $1,500 for the machine alone. All of this was used just one time. Selling to make space.Millermatic 135Syncrowave 250
Reply:Having owned a UCC-305, I'd have to agree with your assedsment of bulletproof and especially BIG.That machine weights literally, half a ton, and will make a good tig/stick machine.  The linde I used to have had a very smooth arc, but I had to sell it because it was taking up WAAY too much space in the shop I work at.  In order to put a mig feeder on it you would have to get a feeder that can take constant current input (most mig feeders are meant for a welding power source that is constant voltage).The water tank would imply he has some sort of cooler for a tig torch, which is a bonus.  I think that he's asking a bit much for it, when I sold my linde complete with torch, water cooler, pedal and some misc accessories I only got $700 for it.  I'd offer him $600 and see what happens.
Reply:Cool, thanks for the advice.  I'll do a little research on getting a MIG setup for it because realistically for my home welding I dont need tig/stick I just need mig.  tig/stick is just something I WANT because eventually I'd like to do some side work welding stuff on peoples fishing boats (lots of potential market for that and I know all the guys down at the boat ramp since I fish w/ em all).Millermatic 135Syncrowave 250
Reply:If you want a mig, buy a mig.  You're not going to be happy mig welding with a constant current tig/stick power supply for your around the house projects.  You need a constant voltage power supply and feeder, or an all in one mig/feeder.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Why wouldn't I be happy with it?Millermatic 135Syncrowave 250
Reply:A welder is an answer to a question. The question is what ya want to weld or LEARN to weld.I'd rather have an industrial grade stick/TIG machine than a light MIG. Get proficient with stick and TIG and you may not care very much about having a MIG. If you need a MIG for sheet metal, get a small portable MIG so you can carry it to the job.
Reply:Anyone know of a manual I might be able to download for the Line type C-300 AC/DC?  THANKS IN ADVANCE!!!
Reply:Anyone know of a manual I might be able to download for the Linde type C-300 AC/DC?  THANKS IN ADVANCE!!!
GMT+8, 2025-12-17 11:07 , Processed in 0.321826 second(s), 18 queries .
