查看: 14|回复: 0
No Aluminum Penetration (New to Welding)
发表于 2022-6-27 15:51:26 | 显示全部楼层 |阅读模式
Hello all, I have the opportunity to learn how to weld on my friends millermatic 251. He has it set up for mig spool and uses 0.035 ER4043 as the filler. I have done very limited mig (steel) welding back in the day during highschool. I am trying to weld 1/8 square tubing which I will eventually be welding into a bedframe. After doing some test pieces I realized I was getting very little if any penetration on my welds. I used the chart on the welder to set my parameters (19v, 400 wire speed) and I used a new grinder flat disk to clean the pieces. I tried a couple different methods such as uping the voltage (As I thought this correlated with bead depth) and messing around with the wire speed. I also tried preheating the metal with a torch. Nothing seemed to make much of a difference. From watching several videos and reading some articles I have learned that the bead depth is actually related to amperage which in turn is dictated by wire speed. Although I messed around with wire speed a bit I for the most part was focused on voltage. Tomorrow I will have access to the machine again and I plan to keep the voltage constant while adjusting wire speed to see if I can increase penetration.Here is a picture of one of my horrible attempts:
Does this appear to be a wire speed issue to you guys? Any additional tips for a new welder? Also I'm assuming in order to test my beads I should be able to bend the square tubing without the weld breaking is that correct? Currently I can break them with a few taps of the hammer which I am sure is too weak...
Reply:You really need to get the metal/arc in spray transfer mode.  I have a feeling you were still in short-circuit.  Look up a few videos so you can familiarize yourself with how spray transfer looks/sounds.  It is a very hot, high-energy transfer mode where you have to move relatively fast.
Reply:Argon left that mess? You sure you're using the right Gas?
Reply:Make sure you are running pure argon, and ditch the grinder for cleaning. In my opinion any power tool for cleaning aluminum is a no-no, as it tends to drive the contaminants into the metal. Stick with a manual stainless steel brush that has never been used on anything but aluminum. Also make sure you are pushing your welds and not dragging. I would start with 21 volts and 350 ipmMiller Multimatic 255
GMT+8, 2025-12-18 09:27 , Processed in 0.091547 second(s), 18 queries .
