Cast iron thread repair
发表于 2022-6-26 15:51:40 | 显示全部楼层 |阅读模式
Problem: Thread portion of this cast iron part, (I don't know how it functions), is broken in half.
Though about building it up with EZtig filler but wasn't sure how it would machine. Thought about nickel99 but it was discussed - not good to machine.So since you can weld steel to cast iron with EZtig I opted for a both.First I machined off the remaining threads on a 45 degree angle.
Next I put a couple of passes of EZtig on the 45. Stuff is kind of sluggish but it works.
From there I built it up with 70s2. I have repaired threads this way before and knew what to expect machining with HHS tools.Experience taught me when you think you have enough metal, add more!
Reply:ContinuedAfter I built it up time to machine. Here it is ready for threads.Attachment 1740878The final results. I hope it holds up.Attachment 1740879Attachment 1740880Ernie F.
Reply:I don’t know why the photos came in as attachments. If you click or tap on them they should show up. I will repost them tomorrow when I go to my shop.The answer to your question is in the first attachment. It was indicated directly on a 4 jaw chuck.Ernie F.
GMT+8, 2025-12-17 10:59 , Processed in 0.146390 second(s), 18 queries .
