Miller Maxstar 161 tig torch replacement
发表于 2022-6-26 15:51:40 | 显示全部楼层 |阅读模式
Hello.Does anyone know where(online) I could buy a low cost tig torch replacement for this machine?Or the size of the plug hole?I don't tig weld very often and need this for a small project. Thanks in advance.
Reply:Also a low cost gas valve...I found some on Amazon but I don't have the specs on the machine...I also don't have the machine on hand.
Reply:What model?  What plug? Dinse or torch connector.  Check eBayLast edited by tapwelder; 11 Hours Ago at 04:20 PM.
Reply:Call USA welds, also known as HTP welders. They have all sorts of CK worldwide products and the dinse adapters to go to various torches and flow thru gas connections.
GMT+8, 2025-12-18 09:29 , Processed in 0.108848 second(s), 18 queries .
