Sp 135 t
发表于 2022-6-25 15:51:36 | 显示全部楼层 |阅读模式
Used my welder last week and today the wire feed doesn't work. . Seems like there is no power to the bottom roller.  I checked the trigger with a Ohm meter and both wires and the trigger are good.  Anyone know how its gets power ??I've owned this welder for 15 years and basically never been off of setting D.  Couple weeks a go I moved to C range and it didn't work. Then I just switched it back to D and welded. Today   have power with on /off switch   just seems like no power to feed roller No wire installed . Not sure what to look for inside . Maybe a fuse??Thanks.
Reply:Looks like there is a circuit breaker on the back of the machine. Don't know why it would trip though.See manual.https://www.lincolnelectric.com/asse...OLN3/IM785.pdf---Meltedmetal
Reply:Try the Voltage selector with again.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:if the above dont worrk, do a search, or go to post #10 in this threadhttps://weldingweb.com/vbb/threads/2...wont-feed-wire
GMT+8, 2025-12-17 11:09 , Processed in 0.099566 second(s), 18 queries .
