Copping a sa250
发表于 2022-6-23 15:51:26 | 显示全部楼层 |阅读模式
So I picked up an sa250 this weekend with the Perkins runs like a dream just doesn’t fit against the cab and I want to chop itIt doesn’t have the sa200 style cap it has the half cap that’s open on the bottom Is it still possible to chop?Last edited by Griffin; 7 Hours Ago at 08:42 PM.
Reply:https://docs.google.com/document/d/1...Af9X8VdIwIZ9ywHere are some pictures of the welder
Reply:Your only limited by your own abilities.Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:And don’t really know much about the welder Sent from my iPhone using Tapatalk
Reply:To be clear, are you looking to chop as in height or shorten as in length?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:I agree with Freebirdwelds and I'd say the biggest challenge will likely be the fuel tank.  May have to fab a shorter custom unitMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:FYI, that fan is mounted backwards.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-17 11:11 , Processed in 0.283227 second(s), 18 queries .
