查看: 13|回复: 0
What do I need on my first TIG welder that I want outgrow?
发表于 2022-6-23 15:51:24 | 显示全部楼层 |阅读模式
I am about to purchase my first TIG welder, I do not want to outgrow what I buy so what min AMP and features do I need to get so 20 years from now I will still be able to use it on anything I might run across?https://My Youtube Channel
Reply:How long is a bit of string?Most people on domestic power get a 200-220 amp single phase AC/DC TIG set as it's very flexible and will allow you to weld up to 6mm/ 1/4" aluminium. If you need to do a lot of 1/4" or bigger, then you need a bigger machine.Do NOT kid yourself that DC TIG is good enough for everything... it's only any good when you KNOW you'll never need to weld aluminium.Murphy's Golden Rule: Whoever has the gold, makes the rules.
GMT+8, 2025-12-18 10:45 , Processed in 0.089284 second(s), 18 queries .
