查看: 14|回复: 0
Inflation fighting plasma..
发表于 2022-6-22 15:51:23 | 显示全部楼层 |阅读模式
I decided to try to adapt a cheap China PT 31 torch head to a Thermal Dynamics ATC SL-40 lead . The SL-40 was finicky, but worked well most of the time.. I have all the SL-60 torch stuff to use on it, and a bunch of low cost China consumables for the PT-31.. I don't have the Pilot arc hooked up right now, but it cuts fine as is.. It's only to get bargin consumables, and smaller front end on the Plasma when needed. Success with the adapting to my 23 year old/ free Pakmaster 50The 25 ft extension lead I nave now works with the 15 fr SL-40 lead..
Also the 35 amp Plasma is a good match to the small torch.. Handful of consumables are nothing to buy..Good swirl rings Keep it cutting well..
Esab/Lorch ET-220iEsab 160i caddyEsab CV353Thermal LM-200/ Lincoln feedersThermal 60i- 3phase Pak 50Thermal 35CThermal 15cINE 1500 Klutch 220iBlue Demon/140 msi/90sti
GMT+8, 2025-12-17 11:09 , Processed in 0.174158 second(s), 18 queries .
