查看: 13|回复: 0
Mig gun troubles
发表于 2022-6-21 15:51:36 | 显示全部楼层 |阅读模式
So I have a Lincoln 175SP that uses the 10' Magnum 100 gun which is no longer supported. I swapped a 15' 250L gun onto it and my welds have gone to crap! Is that extra 5' too hard on my machine? I noticed if I upped the power I could get slightly better welds but spatter and popcorn abounded.Am I limited to a 10' stinger on my lil-mig?Thanks
Reply:Unfortunately...Yup.You can get a 10' replacement whip from herehttps://usaweld.com/collections/linc...ger-connectionthey advertise 10,12, and 15 but I would just stick with the 10'.Last edited by Broccoli1; 10 Hours Ago at 05:40 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Thanks Broccoli, I caved and swapped the 10' back on and my welding prowess has returned. I trash picked a SP100 110v unit with a bad gearbox (nla) so I'm going to 3D print one and try it out for mobile repairs - I had wanted to put my 100L on that one. I guess I'll swap it to test and then the new gun will go onto the 175.
Reply:Realistically 10 footers aren’t the end of the world.  Just requires planning and repositioning of the welder or cart. Pretty much the identical problems you run into with a 15 foot whip, only 5 feet sooner. LOL. Sent from my iPad using TapatalkLast edited by Lis2323; 8 Hours Ago at 07:22 PM.:
Reply:I agreeI used Tweco and had 10 foot gun for aluminum wire. The longer the gun the more difficulty you have feeding the wire.Today my welder has a 6 foot gun but life the welder w/wire too. I also have 8" wheels so moves easily even over dirtMy old wire feeder (Miller 30A) with wire was about 120 pounds and the wire was exposed 😳. Dave
Reply:Not sure what size wire you are trying to push but 023 and a 15' gun will be disappointing. Plus those little SP and Weldpak units had a pretty weak feed motor and when it labors it will lose some wire speed. There's a million 10' Tweco style mig guns on Amazon for $50 or less.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:i dont think id be so fast to accept the extra 5' is the cause on this.     id be taking a close look into  a connecrtion/feed related problem first
GMT+8, 2025-12-18 14:00 , Processed in 0.086473 second(s), 18 queries .
