Miller 251 not getting gas
发表于 2022-6-20 15:51:32 | 显示全部楼层 |阅读模式
I have a 04 Miller 251 that’s not getting gas past 20 cfh. Before 20cfh the solenoid works. But past 20cfh it quits. I’ve replaced ( solenoid, liner, regulator) I’ve checked all the hoses. Until I tested the wires that run to the solenoid. There getting 16.4v I’m lost as to what my next steps should be. Do I get a new circuit board?
Reply:It could the solenoid or the PC board. Need to check out solenoid to see if workingDave
GMT+8, 2025-12-18 12:37 , Processed in 0.131214 second(s), 18 queries .
