They said it wouldn’t work. But here we are…
发表于 2022-6-20 15:51:31 | 显示全部楼层 |阅读模式
After 3 years I finally milled something on my drill press.For $145 XY I did not have higher expectations than what I got, but it worked.I think i took incredibly small cuts, maybe a heavy 1/32” at a time with the cheapest 3/8” end mill on Amazon.I also used a 4 flute, instead of 2 flute for aluminum.But, I got the job I needed to done even if it took 2 hours to do all 4.By no means is this practical but it got the job done.
www.FirehouseFabricators.comZachMillermatic 255Lincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Glad it worked out for you.Question, did you ever consider using a table saw instead or did you want to see if the drill press would do it?.........Mike
Reply:I have made LOTS of parts like that,,, using my metal cutting bandsaw, even out of steel.If it is a straight cut, the bandsaw can surprise you.In your case, the bandsaw could take out 90% of the material in minutes, then drill/mill the remainder,, best of both worlds,,,
Reply:Nice, sometimes you do what you gotta do and sometimes you do cause you gotta see.
Lincoln 330MPXLincoln Power Mig 256Lincoln LN-25X Wire FeederMagnum PRO 250LX GT Spool GunLincoln AC/DC 225¼ Ton of Torches OFC-A OFG-AAir Carbon Arc Gouging CAC-AEverlast 62i Plasma CutterIngersoll Rand T-30 14hpInstagram: #Freebird Welds
Reply:nice u made it work, but what is it (whats it do)  ?      they got endmills w/ radius corners too if u want
Reply:That a drill press?  Or a drill/mill? Does not look like an average drill press.After the first 1/32” pass,  I would have thought it works.  Then hogged off some metal with other tools.  Probably would take 2 plus hours finding the best tool, but the second one would take 15 min.
Reply:Drill press.........................  Good for bragin' rights, but it's just aluminum.
GMT+8, 2025-12-18 12:42 , Processed in 0.162178 second(s), 18 queries .
