Is this air hose reel junction repairable?
发表于 2022-6-20 15:51:31 | 显示全部楼层 |阅读模式
I finally found the leak that sucked my compressor dry. 100' of Husky air hose on a Husky manual reel. The black arrow shows where the leak is. The red arrow points to the stem that's really floppy and feels potentially suspicious to me. I bought it on FB Marketplace. Theoretically Husky has a lifetime warranty but they don't make this any more. I prefer a manual reel and my 100' of hose.So these fittings are new to me. I don't know where to get replacements or if a replacement/repair is even possible. A new manual reel is $25 - $30. I always think of repairing before buying new but in this case is it even possible or worth it?
Reply:Definitely repairable. Those swivel fittings use O-ring seals. Take it apart, replace the O rings. Keep in mind that the old O rings are going to be compressed, so don't use them to size your new O rings. Measure the O ring groove and the bore that they seal against.Make sure you lubricate the O rings. You want to use grease, not oil, here. Make sure that the grease you use is compatible with the type of O rings that you use.I recommend Buna N O-rings for this application as they aught to be more abrasion resistant. A combination of abrasion and the O-rings taking a set (permanent deformation) is likely the cause of failure. Here's an O ring kit. Go ahead and buy the Metric and SAE. Never know when you're gonna need an O ring! https://www.amazon.com/BUSY-CORNER-U...8-3&th=1&psc=1Sent from my Lincoln Buzzbox using Tapatalk
Reply:Only way I can figure out how to take it apart is that one nut. Is that all there is to it?
Reply:I'm going to head out to my shop in a minute. I'll take the one off my hose reel and take some pictures.
The only seals should be inside of that brass piece that your quick coupler is attached to. Just a pair of O rings. Other than that, it should just be NPT fittings. Undo them, add some PTFE tape (I like Hurcules MegaLoc), and tighten them down.Sent from my Lincoln Buzzbox using Tapatalk
Originally Posted by 12V71
Is that a snap ring to the left under the red arrow? Ok, I'm too slow.
Ok, I'm too slow.
Reply:Yep, a snap ring. It was rotated around back and I didn't see it. But if a nut is there, I'm guessing it'll unscrew for further access. I'll get into it tomorrow, can't tonight. The wife wants me to watch a movie with her.
Originally Posted by 52 Ford
HA! Hopefully it isn't something like "The Notebook".
Reply:Top Gun 1
Reply:I forgot to take a picture of the hose reel swivel...HERE! I drewed you a picture! You're gonna hang it on the fridge, right?Sent from my Lincoln Buzzbox using Tapatalk
Reply:Thanks! I have a frame just that size somewhere. I don't see a signature though....The drawing will help when I get into things in the morning.
GMT+8, 2025-12-18 13:52 , Processed in 0.089256 second(s), 18 queries .
