Who is the resident bearing guru?
发表于 2022-6-20 15:51:30 | 显示全部楼层 |阅读模式
II was wondering if there was a cheat page to the nomenclature.  Its like belts and hose fittings, hyd stuff, I just cant remember all the details and didnt know it well enough at the time. Wonder if there are cheats to cross mfg.www.urkafarms.com
Reply:Today I use the internet and McMaster. When doing a lot of repair work I had catalogs that helped. I only keep my bearing catalogs.  On V-belt there a easy way to cross reference by using the outside belt dimensions but forgot Dave
Reply:Dang, it would have been my late dad. He spent 27 years as a maintenance machinist at Timex. Before that he was a tool and die maker. I swear he knew everything about everything. I have all of his tools and handbooks now. Let me look through and see what I can come up with (if anything)Miller Multimatic 255
Reply:Most tool and die makers was from WW2.  It is trade that always need. I do not know what do when last few retire. Today the repair machinist are hard to find. In August 13 2009 I was offered a job as repair machinist at $37.00 with at less 500 hours of over time.I would taken but I was in the hospital with stage 4 cancer . Dave
Reply:It is sad day to see no training for tool and die. I do not know who you true too for war. I know China can do job.Dave
Dad was born in 1941, so he was technically trained after both WWII and the Korean war. He graduated technical high school in 1958 and did his 8000 hour apprenticeship at Anaconda American Brass in Waterbury (brass capital of the world). They are still pumping out "machinists" at the tech high school but they are all trained only on CNC now. I am not sure there is anywhere around here you could go anymore to be trained as a tool and die maker.
Reply:I do have a union card as journeyman repair machinist.  But formal training is in Engineering and licensed in structural steel . It very good line of work.Dave
Reply:Came across this one after Caveman said what to look for... give's #'s but no spec's....https://www.ahrinternational.com/PDF...eGuide7536.pdfThe harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I’m not certain but I think my old SKF catalogs used to show what you are looking for. Sent from my iPad using Tapatalk:
Originally Posted by CAVEMANN
You need the IBI  book, INTERNATIONAL BEARING INTERCHANGE, I don't know if it's still in print, but I used it extensively during my machine shop time. It listed bearings by size , seals tapered, barrel roller dual barrel etc and interchanged to different manufacturers numbers. It is available in digital format by searching for it, you may find a used set if you look.I did find it in a PDF, but you' have to create a free account to use it, personally I hate those sites.
GMT+8, 2025-12-18 09:25 , Processed in 0.105719 second(s), 18 queries .
