查看: 14|回复: 0
Carbon arc rods for stuck nut. ?
发表于 2022-6-20 15:51:30 | 显示全部楼层 |阅读模式
Hi new on here , looking for help have a chewed manifold nut looking to get it red hot but don't have oxy burning gear , came across Carbon arc rods ? Wondering can you attach 1 to the earth ,1 to the electrode side and basically put it to either side of the nut at about 70 amps ? Will it short and heat the nut up ? Or am I way off track ? Thanks
Reply:I don’t know if 70 amps is sufficient but carbon electrodes can definitely be used to get that nut glowing ,either as you described or with a carbon arc flame.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Try welding a nut on top that should heat it upRetired Old GuyHobart 210Lincoln AC/DC 225/125 Evolution 14” Saw
Reply:[QUOTE=jpump5;8867644]I don’t know if 70 amps is sufficient but carbon electrodes can definitely be used to get that nut glowing ,either as you described or with a carbon arc flame.[/QUOTEi can go higher than 70 amp just read somewhere about that setting and thawing out pipes etc , if I start the carbon flame would it not just melt the nut and the manifold ?
GMT+8, 2025-12-18 13:53 , Processed in 0.061819 second(s), 18 queries .
